Washer problem...
Hi, new to the Vrs thing, only a week in and got a problem! My window washers won't work, the headlight washers work fine, but nothing on front and back screen. Is it a switch/relay issue or a maybe a broken connection somewhere? If anyone has had a similar issue it be good to hear what you think! Thanks
Pretty sure the headlight washers share the same motor so It'll be a pipe connection come off somewhere.
The motor doesn't run when I pull the washer on though, and no visible water anywhere
