fun rear archs
hi there guys does any1 know if u can buy fun rear archs or u got to cut out and weld as mine are shot
regards
dil
I'm pretty certain you can't buy the rear wheel arch repair panels for a pickup any more, you can definitely still get the hatch/estate ones though and they are fairly similar, it might be possible to chop the piece out you need from a hatch/estate arch repair panel but it depends how bad they are really.
Hi dil1986,
It depends how bad you're talking. I suspect your main option will be welding to repair/strengthen, but I had similar works carried out to the near side turret a while back & have had to repair at least twice since! They're a RPITA along with the other areas that are equally prone!
If you can't do it yourself there should be someone nearby that can assist. :happy:
