ECU reconditioning
My S Reg 90bhp TDI has developed what I think is the shudder on returning to idle that VAG admitted would happen to all TDIs with ECUs of a certain serial number :mad: . I have been quoted
Anyone?
Can someone at least tell me how to get to the ECU, I cant find a haynes manual for the car and the MkIV Golf is different.
ECU is in the same place as the Mk4 Golf (under the scuttle panel); Remove the wipers, then the rubber weather seal then carefully remove the scuttle panel. ECU is then near the middle somewhere and is held in by a fairly simple clip. The other option is to find someone with vagcom who can get the ECU number for you in a couple of minutes.
Try calling Micheal at Jabba, he is bit of a dab hand with ECU's.
EddyH: Thanks...I am going to have it plugged in and checked asap.
VRStu: Cheers...I will give Jabba a call, I didnt know they did ECU refrubs?
May not be a refurb but they have all the equipment needed to recode or possibly repair an ECU. It may be possible to get a used one from a breakers, they were around
