Led number plate light
Hi
I'm wanting to change to these but have read a lot about these throwing up the bulb out warning light. Can someone point me to some that don't thow up this warning please.
Thanks in advance
Neil
I know Mike Holroyd has changed most of his bulbs, give him a shout, he'll probably have a good idea.
I've changed mine. I'll try and post a link to the one's I've got.
On my phone at the moment.
Thanks for the responses so far guys.
Simon thanks for the linky.
Would the year of registration make any difference to the bulbs I get? Or does that not make any difference to the canbus?
they are not cambus related light on the number plates
On the pre FL that's correct but on the FL they are.
Sent from my iPhone 5 using Tapatalk.
On my Octavia RS (March 2012) i put some cheap led bulb and then enabled "license plate LED light" with VCDS and i have no errors.
As 'le Profesor' has said, yes, I have changed the number plate bulbs in both my Octavias to LEDs.
I use 3 SMD, ultra white 38mm festoon LED bulbs from Fizzmo on eBay. Fabulous next day delivery, and a great, long-lasting product too. If you do need the ballast resistors then they will supply these as well.
I can't recommend them highly enough.
Mike
Hi
I have a 2012 Vrs hatch and would also like to replace both my Interior and number plate bulbs will these bulbs work as is without any errors or other issues on my car or would I also need these ballast resistor things you mentioned and if so how big a job is it to fit them also
Paul
Edited by Bigboy
Do the fizzmo ones work in a 09 fl?
