Mitsakosgt Octavia GT 193 build!
Fitted!!!
More...
Do I need shorter bolts???
Gave her a wash today....
Where did my seats go?????
Now its better.....
Detailed info tommorow....better pics also...
As promised here are some pics of the install...
First I took the old seats off
Then I put the power cables under the carpet and out about the same length as the airbag cables
Then I had to change the air bag connectors as the Recaro seats had a different style than my OEM...
From this:
To this:
And here is the result
More...
The only thing left to do is to power them up.I found some fuse box connectors so I can make it look factory fitted!
Yasterday I fitted the freshly painted front grille.Here are some pics....
20140514_150709_RichtoneHDR_zps6776c75c.
20140514_150730_RichtoneHDR_zps681cd426.
Nice motor, right colour too! ;) Looks like it's been lowered since the wedding?
Thanks mate!!!
No its not lowered,its the same since I got it....it has the KW sport kit(springs and shocks)since new! ;)
What engine is it, 1.8T 150ps?
Its Ok googled the GT and answered my own question, 1.8T with 193ps output supposedly.
You're correct mate! It came as a1.8T with the 193ps map!
  • 2 months later...
Right on duty.....
 5bcb9b10ff2ed5f26b431de01cd6d9a2f6fda58b
  • 4 weeks later...
So,as I was bussy the last months,I finally got my hands on these coilovers......Bilstein pss9 kit,fronts need a rebuilt but I got them for cheap so I dont care so much..
What top mounts should I use???? I am a little confused....
  • 4 months later...
Fitted!!!
Hey, I have been lucky enough to find a Dahlback Manifold like yours. I am just wondering what did you do with your FPR line and DV line which fits into the bottom of an AGU inlet. As the dahlback one does not have these fittings?
Hey,good find mate!As you can see from the photo above the fuel pressure regulator is Tee'd on the middle of the intake manifold where there is a nipple for that.The DV valve is plugged at the same spot if I remember correct.I ll try to take some pictures for you later today!
