Octavia VRS TDI DE_CAT
HI, I have a VRS TDI Octavia and the DPF has died, im looking for a de-cat pipe. Can anyone tell me where to get one from and how much I will be looking to buy one ? cheers Ben
Cat & DPF are 2 different things
You need a DPF delete & the car will have to be remapped to make it run
Talk to Shark Performance or similar companies. Its not a DIY job
Make sure also its the dpf that's died as there are other things that give the symptoms, a decent search on here should throw up more answers,    put DPF DELETE into the forum search, change topic to forum  & see what it throws up
Edited by Stuart_J
just been looking at there web site and some others cheers m8
Depending where you are based Jabbasport are pretty good, Ive used them for mine & they did a cracking job   http://jabbasport.com/
Are you sure its dead? could a forced regen not fix it. Im sure some can be rescued.
