vagcom scan results. give us a clue?
Just had a scan and here are the results.
Air flow flap has already been disconnected to stop the clicking so not worried about that.
What should the max boost pressure be on a DNA stage 1?
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: Mileage: 250930km/155920miles
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 10700
Shop #: WSC 66565
VCID: 6DDBD76D278ADF1
TMBSL21U228541536 SKZ7Z0A1032926
1 Fault Found:
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-A.lbl
Part No: 1C0 907 379 F
Component: ESP ALLRAD MK60 0104
Coding: 0023174
Shop #: WSC 31480 000 00000
VCID: 2D5B176DB70A1F1
No fault code found.
Address 08: Auto HVAC Labels: 1Ux-907-044.lbl
Part No: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 01000
Shop #: WSC 31480
VCID: 30650E19F038729
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605
Component: 0L AIRBAG VW51 0B 02
Coding: 12364
Shop #: WSC 31480
VCID: E1C33B5D6B520B1
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
Part No: 1U0 920 911 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 23412
Shop #: WSC 25028
VCID: 2E591061EA0C649
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
VCID: F0E54E19B0B8B29
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F47FDA59DA6FD1
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 3Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31480
VCID: 36693801125C5C9
Subsystem 1 - Part No: 1U6959802D
Component: 3Y Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1U6959801D
Component: 3Y Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1U0959811D
Component: 3Y Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1U0959812D
Component: 3Y Tõrsteuer.HR KLO 0002
5 Faults Found:
01030 - Central Locking Key Switch; Driver Side; Lock
29-10 - Short to Ground - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
End ---------------------------------------------------------------------
Just done a quick Google.
A lot of threads seem to point towards N75 or associated hoses.
I've got a spare one from an AGU IIRC.
May be of some help to you !!
I know I have a leak at the crank vent as it is split,  got a new one to go on but not got around to fitting it yet..
just did block 32 and they are as follows:
Group A: '032
Adaptation (Idle) 2.8
Adaptation (Partial)   -10.2
from memory the positive 2.8 at idle signifies the vac leak from the crank breather and the negative 10.2 indicates a boost leak :(  still hits 20PSI though????)  must get around to fitting the TT IC's and pipework as that joint behind the block is a pain in the rear to get at.
Negative means its cutting fuel as its running rich. Could be a knock on from the split. Plus the over boost could be from a leak that the turbo is trying to compensate for and its overboosted whilst trying.
I'd fix the crank breather first and go from there.
Its only a ten minute job normally although you got the spiders web over the top iirc :o
Sent from my GT-I9300 using Tapatalk 2
no the spiders web (lpg) is above the manifold, just have to get hold of a dipstick before attempting it (just in case :D) might have to clean out the check valve again though as its been on for 60K+
so would I be right in thinking that I have a problem with my CCU :D
Any takers?
5 Faults Found:
35-00 - -
New CCU needed? or something in the door?
I would check the wiring in the door, between the door and body and the connector behind the bonnet pull first.
Sent from my Nexus 4 using Tapatalk 4
