Oil pressure fault
Please help Hi problem with oil pressure warning light coming on now and then it came on at high speed turned car off wen restarted no light came on again 50 miles later so changed the oil used flush was fine for 1000 miles then tonight it did it again this time at low revs had a look around found badly split breather pipe but I don't think that would course this the car never uses any oil no loss of power or boost this has me stumped any ideas thanks
Oil pickup pipe blocked mate drop sump and clean it out or best buy new dont use car or ull starve turbo nd blow it or even worse blow engine
as above
