Breaking Mk1 Fabia vRS - lots still available!
Gearbox gone? :)
  • Replies 237
  • Views 18.4k
Did you get rid of the front and rear seats mate? If not, what condition are they in and how much for the lot?
Sent from my GT-I9505 using Tapatalk 4
Gearbox gone? :)
Sorry I'm using it
Yep sold today
Have you got the drivers side wheel hub
If its not accident damaged
Has the front bumper gone yet mate? What colour is it and how much if not? Pm me please
Random one - would you have the bolt and rubber bung for the airbox. Infact how much for the air box and bolt etc?! Thanks
Sorry it's already provisionally sold
It's damaged beyond repair
The bolt and bung aren't available, but the bung for the push on fixing is. Depends which bit you need?
Airbox is also still available.
Hi there im looking for the drivers side or both sides of the front grille fog spoiler............the grey bit that fits behind the front spoiler which the coloured spot light surround clips onto??  Thanks in advance
Ok thanks anyway
Looking for TOP boost pipe that goes into the EGR from the plastic pipe please?
Sorry they're gone
Sorry I'm using it
Passenger electric window switch?
Gone already!
Fog surrounds? And grill bits..
 Gone already!
Hi Jambro,
I'm after the plastic plug connector that attaches to the vacuum solenoid block on top of the o/s strut mount. The one with all the vacuum pipes on it. It has part number 6Q0 131 075 on it. I don't need the vacuum pipes or the solenoid block, just the plastic connector.
If it's available and all 6 lugs are intact (one of mine has snapped, hence needing the part), how much would you want for it posted to Newport?
Cheers,
Nick
Looking for drivers side electric mirror switch/adjuster?
After the rear drivers side caliper. You got one?
Looking for an Alloy Wheel?
Hi Jambro,
Cheers,
Nick
Hi Nick
Sorry that part went with the vacuum block
Gone already!
Using the brakes myself!
Sorry selling as a set!
Lots of parts gone, but plenty still available
Post if you need anything!
Hi mate how much for the smic, an have you got the nob for the switch on the heated mirror control on drivers side door?
Hi mate do you have the front panel, front bumper, cross member, head lights, radiator, Radiator fan and drivers side bonnet hinge. Thanks
Got the cross member, driver headlight, radiator, radiator fans, bonnet hinges
Where are you located?
Sorry gone already
Guest
