enabling cornering fogs on vcds - 2010 VRS
Hi all
I know there is a thread on this, which shows a screenshot, but can someone give me a simple menu idiots guide to find the enabling screen for this please?  I am a VCDS newbie, and still nervous of messing something up!
Many thanks
Matt
Thanks, I have the screenshot - I just can't tell which menu that is in - elecs, instruments etc - anyone able to tell me off the top of their heads?
i've found it, thanks for your help
ok, apologies if I am being dumb with this, but...
I have coded the cornering lights, getting a bit more comfortable with navigating VCDS too.  The coding is as per the above screenshot, and the coding was accepted and was all correct on the system after going back in to check, but the fogs aren't working.  I was thinking that this would be as it was daylight, but even with my hand over the light sensore enough to trigger the headlights on, or manually switching to dip beam, they are not activating with either turning or indicators.  Byte 17 I have ticked LH/CH lights, ADL and byte 0 cornering light.  I show another option on there that is unticked and doesn't show on the screen shot above, something to do with bi-xenon, but as I don't have xenons, I have left it unticked and ignored it.  Any ideas what I am doing wrong or what I can check?  I guess I can get a screen shot if needed.
I was looking through my user book and I'm sure it said cornering fogs was only available with the xenon headlights??
Do not work on mine and have std lights.
ah, ok, that would explain it, noone mentions that on the other thread - has anyone made this work with standard lights?
Cornering foglights do work with standard halogen headlights.
There are two types of 'cornering lights' on the MkII Octavia.
1) Xenon headlights (factory option) otherwise known as AFSII have a function where the dipped headlights turn with the steering wheel.
2) Cornering fog lights that utilise the front fog lights.
I've coded this and working on a Blackline which aren't available with xenons so defo works with standard lights.
Dam, dam, dam...been out and tried again on mine from reading the book. Drl's off, lights on dipped beam, engine running, not moving and operate indicator! Nothing diddly squit.
The xenon bit I re-read and that is for cornering main lights need to be xenon's, not needed for cornering fogs, sorry to mislead.
Is this not standard feature on a vRS? Or do I need auto headlights?
try with the engine running and turn the wheel left / right. see if that actibates them
my cornering fogs r triggered based on steering angle only, not on indicators.
i much prefer it this way.
Jr rs- your car looks amazing in yellow!
I will have another play around today, def not activating on indicators or steer. I'll update when I solve it!
My '59 plate vRS has cornering fogs enabled (no xenons). My choice was to have this just on steering wheel angle, but it also worked with the indicators.
Edited by GriffoVRS
