Bulk head
Sat here with the car in bits!!!!!! Trying to fit boost gauge, where can I get access through the bulk head for the vac pipe ? Can't see anywhere, phot would be good :-)
Remove wiper arms and scuttle panel, there should be a black plastic box/lid on the o/s bolted to the bulkhead. This is the cover for the interior relay plate, this is where the factory cruise wire feeds through to the engine ECU (will post pics from the cruise instructions) you can just drill a hole fit a suitable gromet and away you go.
Thanks for the reply, but i went through where the main loom goes through right up behind glove box to the left, really easy to do ( thanks to Phil W)  I asked him so many questions about that, wiring etc which enabled me to do the install on my own, and i'm crap at that sort of thing!!!
A tech quide would be good I'm thinking of doing this myself .)
That's interesting. A few weeks ago, I was fitting a stereo install to mine, which required a large cable to come from the battery terminal, through the bulkhead and into the passenger cabin.
I looked around at the bulkhead, and I saw where this loom goes in - but couldn't see an obvious routing point?
I ended up just drilling a new hole in the bulkhead behind the glove box...
