vrs 2.0. pd tdi timing
Hi boys and girls.
i have just had the cam belt and water pump changed by a local garage, ever since then its been smokey and sometimes even misfiring on tick over, above tickover its fine just the odd puff of black smoke on gear changes :giggle:
no faults showing up in vag-com
checked the injectors and they are all within there limits
egr is clean ish
i think its a tooth out because
vagcom - 01 engine - block 04
806 /min  RPM
  4.8 °ATDC  Ign. Timing
  4.6°KW  Idle Stabilization
  2.63°  Steering Angle
timing seems well advanced to me ?????
i think ive seen the steering angle what ever it is should be a zero or as close as poss ???
Martin
What was the Torsion value in group 4?
That's the best indication the timing is out. If it's out by a whole tooth I'd be surprised it's still running without damage....more likely they didn't get one of the cam locking pins in properly so the timing is just slightly out.
Either way, it does seem that the timing is out and the garage that changed the belt needs to fix it.
Edited by booke23
That's weird, because with my VCDS, on 01-engine, meas blocks - 08, group 4.....the 4 values I get is Engine speed, Injection start, Injection duration, Torsion value.
I've got 12.12.0 too. Is your's a common rail?
Beats me! Perhaps on the PD170 the torsion value is in a different measuring block or is called something else.
Either way, I think you've certainly got a good case to take it back to them to check.
Edited by booke23
Just having a nose on another forum and they saying "I think it's mislabeled as steering angle for some reason under group 004" so I'm not the only idiot that carnt find it lol.
It's going back in tommoz, and there going to check it, so fingers crossed. Ill let you know what the out come is.
Hi boys and girls.
egr is clean ish
806 /min RPM
Martin
Martin, the ignition timing is retarded, After Top Dead Centre, seems to be normal at idle otherwise the ECU would set an out of range code based on RPM and throttle plate values.
Sent from my LT26i using Tapatalk 2
Hi guys. Well I collected the car and they told me they have moved the cam position round a little, so it was a tooth out on the timing !
Tickover is back to how it was before the belt change, still a tiny bit of smoke. Vagcom still says timing is 5deg after top dead center on tick over but the steering / torsion is now 0.6
Could someone confirm this timing on there 2.0 pd please.
I checked mine earlier today out of interest. The torsion value was at 0 exactly. 0.6 is fine though.
IIRC the cam sprocket has 44 teeth, so if it was a tooth out it would be 8 degrees out.....and probably a bent valve or two. On the PD engines, when replacing the cambelt, the cam sprockets bolts are loosened to allow the cam sprockets to spin on the cam shafts.....this is required to tension the belt properly. You have to lock the cam shafts in position with locking pins before you loosen the sprockets. But it's tricky inserting the pins......the difference between inserting them properly and not is very subtle. I suspect they didn't get a pin in properly and that is why it was only out by 2 degrees or so......very lucky there was no damage.
Glad they sorted it for you.
Thanks for your help guys I'm pleased its hopefully sorted now, the cold start in the morning will tell.
There so many folks on the net with this sort of problem I was thinking its a start of a nightmare lol
Once again thank you all.
Beers on me
  • Like 2
  • 4 months later...
Hello I'm french and I have the same problem on my 170 tdi
I plan to make myself a setting.
it must adjust the cam front or rear or both at the same time?
My values ??are:
883 TR / MIN
1 °
4.7 °
2.97 ° Torsion
thank you
Hello
how is the setting for I am to 2.97 torsion value
thank you
As mentioned earlier in the post, torsion value should be between -1.5 and +1.5. Ideally it should be 0.
Yours sounds like it needs adjustment.
Because since the change of timing belt by my Audi dealer my car smoke and hard to start cold
Certainly sounds like the timing could be out. But I would take it back to the dealer and get them to fix it.
My car is already at the dealership for 2 weeks.
They changed 4 injectors and seals, cleaned the DPF, EGR controlled.
I was told to control the belt and adjust to 0 but for them the belt is OK.
They are really stubborn and do not want to listen to me
So I'll get it back Monday and make the setting to 0 myself.
Are there other settings to adjust?
Hello
Since 2 days I set my timing belt and I have no more problem.
Perfect boot to cold
no white smoke
no smell diesel
stable slow-motion engine
sync my angle is now -0.74 hot
before I was 2.97
  • 7 months later...
Hello,
I also have a TDI 170 PD. All the torsion values listed in this post were measured with the engine hot?
I ask this because i have 1º difference variation : when engine is cold my torsion value is 2.5º and 1.5º when hot.
Is this a normal variation? I believe that some of my cold issues (bad cold start, shaky idle) come from this but i'm not sure...
Thanks!
Edited by evildream
