help hi from brighton
Hi need help with imobiliser problem.
Hi & welcome
Welcome.
hi is it a felicia your having problems with imb on
Hi and welcome aboard.
Hi and thanks foall the welcome messages, we have had a problem with the ignition switch, which we have now drilled out and replaced with a switch and start button. We have putkey in to transponder ring but still cant getthe imobiliser to go of. We are at present time very short of cash and have looked at new key transponder ring and ecu and reprograming. But this would cost more than the car is worth. We have rebuilt the starter motor . Every thing now seems to work we just need to bypass the imobiliser so we can get a few more years out of the old girl. Thanks in advance for any help. Paul and caz.
Is it a 1.6 or 1.3 you can buy pass this
It is a 1.3 the ignition switch has broken so drilled out and replaced with switch a button start but cant get imobiliser off.
Have you connected the white wires up.....
Welcome  :party:
Is this running yet.....
