Garrett GT1749vc based hybrid turbo for PD130 ASZ 1.9TDI
Why the change in design?
Anyone fitted one yet?
Same bhp output?
  • Replies 136
  • Views 39.5k
  • I must stop looking at this thread, all these shiny turbos are doing nothing for my will power to keep my Fabia standard!!!!
  • ok I will explain here so I don't have to PM someone every 5 minutes   Basically it is stock GT1749V turbo from ASZ engine, reconditioned, sandblasted etc. looks like new to me, with GT1749VC (PD17
  • ok one is gone already only one left in stock, I can get hybrids or rebuilt stock turbos for pretty much any car so please PM me if you are interested   I do also have in stock GT1749VC hybrids for
there is at least one fitted I know off the design has been changed because the PD170 turbine wheel turned up to be to large and heavy for small stock exhaust housing in some cases causing late spool and some overboost issues. The PD150 one seems to be working just fine however I have yet no RR plot to show
Still got some? What power will it make on a pd150 arl?
195-210 depends on the supporting mods and engine condition
there is also an option to fit GT2052V cold side housing and comp wheel and PD150 shaft however it will require larger diameter boost pipes otherwise fits P&P, this should bee good for 220bhp or so £450 delivered
cheers
Any of the above mentioned turbos in stock?
I want the easiest available turbo that will take me past 200hp safely. 210+ would be great. Gtb1756 is tempting but needs a bit more tweaking.
none in stock sorry I take deposits and waiting time is roughly two weeks now. For 210bhp+ I would suggest this kind of hybrid:
http://www.briskoda.net/forums/topic/326620-garrett-gt1752-hybrid-turbocharger-for-20tdi-pd140-bkd-bkp-220bhp-potential-bargain/
stock exhaust side, PD150 shaft and GT2052V cold side meaning you will have to use larger diameter boost pipes or some adapters otherwise everything fits as stock (the turbo in the link above is obviously for 2.0TDI so the one for 1.9TDI will come with different manifold to fit P&P)
cheers
  • 4 weeks later...
Hi Xman,
I've got a 56 reg fabia vrs 1.9tdi, blt engine needing a new turbo, have you got anything available?
Cheers,
Rory
Hi,
what's your power goal roughly?
cheers
or do you want just stock turbo ?
Didnt really have a power goal in mind, nothing major 170bhp would be nice.  Have you got anything that would suit? Or do you have just a stock turbo?
A stock pd150 would be fine, the EGR port is in a different position though.
I would have to order one in for you could you please PM me tomorrow and we will figure this out
Hi, any chance of selling a turbo for my ASV engine? I've done a remap, EGR delete and looking for some better turbo now. Thanks
again what's your power goal? and you should do remap after fitting larger turbo not the other way around. What boost pressure are you running at the moment?
cheers
another 2 in stock
Hi, are these still £380 delivered?
no sorry £400 delivered now
up
Is this still for hybrid 150's?
I don't really understand your question to be honest...
Sorry i mean are the turbos still available and are they still the pd150 hybrids
I cant afford the bigger one, but im certainly interested in gt1749vc hybrid,is the price still £400 posted?
Is it ok to pm you a few questions?
