door locks
My car keeps randomly locking it's self does it all the time sometimes it will lock so I unlock it with the button on the drivers control unit and it will lock its self straight away again
Anybody shine any light on this?
I don't want to sound patronising. So I do apologise if I do. But the car automatically locks itself when you go above 15kmph I belive. Is this what's happening? It also auto locks itself when you unlock the car and don't open any doors.
I believe this can be coded out via VCDS though.
Talking of locks. I had some fun with mine today. Parked up and left a passenger in the car. Locked the doors (out of habit) but as i walked away, I realised what I had done and quickly unlocked the doors. Went into the shops and the alarm went off!
Car locked itself as I had unlocked but didn't open any doors. PITA but guess it's only doing what it's programmed to.
My auto locks have been turned off it doesn't lock over 10 mph but just randomly get the urge to lock its self
Does the interior light work correctly? I would suspect water gas got into the controller in the door, or the wiring.
Sent from my Nexus 4 using Tapatalk 4
Yea the interior light works should I change the control unit on the door card?
I would have a look for water ingress in the door and wiring from the door to car.
A will do this when it stops raining thanks
Does the door open light work properly on the drivers door?
Any fault codes stored
Yea the red light at the bottom of the door comes on yes and a dont know about the fault code i havent got a cable
Without some form of diagnostics you are guessing. VCDS will tell you what's going on with each door etc.
Yea al try to find a place that will turn the auto locking on over 10mph it might be vecause thats turned off do you think?
No, I think there is a problem, the locking shouldn't behave like that.
Ok al try my friends door control unit and see if that cures it
