RNS-510 columbus restart or reboot repeatedly !
On 11/04/2021 at 13:52, mushroomnr said:
So ignore my previous messages :)
I have found solution with all up to date files instructions as well. Have a look below
https://www.drive2.com/l/465526077448520463/
If someone struggling with Russian google would translate for you.
Mine's just done the same bootloop out of the blue. It's a LED version with DAB+ and an SSD - no hacked firmware etc. I will try following this guide and see where I get.
  • Replies 76
  • Views 64.3k
  • Yes. Try this before you start throwing firmware discs at it. <, > & i at the same time.
  • Posted last year:   I recently had the dreaded constant reboot problem with my Columbus, the one where the software fails to load properly and just goes into an endless cycle of re-booting. Most com
  • Cheers KBPhoto.   All done! The burn to disc was successful and the update took first time. I'm a happy chappy.   Thanks very much for all your assistance/advice/encouragement!   If there's anyo
So I first tried the SWL Fix ISO on this forum - burned a CD'R at 10x speed and put it into my headunit. It started to initialise then gave me an SWL error. I then tried again and it did the same thing, then thought it was not working and left it.
Got into the car a few hours later and it started working! All my settings were intact, and maps - the only thing that was wrong was my music was wiped from my HDD which is no biggie. Not sure what the SWL Fix does but it worked for me.
