BT retrofit microphone doesnt work
I've fitted a new OEM 7P6-035-730-J bt unit (mk2 octavia, bolero, no maxidot, or multi function steering wheel) without touching the coding the bolero uses the telephone and pairs with phones to make calls fine. However it seems the mic just doesn't pick up sound. I had a look with vcds to see what was being reported. Under 19 CAN gateway I added telephone 77, then updated the coding. My scan is still giving me errors though. Is it a duff mic or something else?
Heres the log:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Sunday,13,October,2013,10:40:11:03878
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: TMBBJ21Z2C2158640
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 AK    HW: 03C 906 016 C
   Component: MED17.5.5       G   9059
   Revision: LCH13---    Serial number:
   Coding: 0000072
   Shop #: WSC 73430 790 00066
   VCID: 68D9FDBE5B7CFD5E3C3-803D
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BF3B2F23AEA46C6C11-802E
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CF1B1EEF7E441FEC8B-8029
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 4E000AB8A05BB1C04010008011000164430000AE727D8960DCC440000040
   VCID: 3F8B06E2AE729AE6AD9-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 17021  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 270212 05  54  0403
   Coding: 0730ED
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
2 Faults Found:
03156 - Sensor for Anti-Theft System (G578)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 13926 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 18:33:22
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.55 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
00907 - Intervention load Management
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 13926 km
                    Time Indication: 0
                    Date: 2018.14.04
                    Time: 10:18:48
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901205104140
   Coding: 10800E
   Shop #: WSC 13765 790 00066
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_SK35.rod
   VCID: 33635AD29A3A4E86591-8066
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2VCJ7Y
   Coding: 0020788
   VCID: 3D777CEA647E88F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME6A4140376
   Subsystem 2 - Serial number: 6342MSME6A25490BJ
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20120229800740
   Coding: 5080140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 77FBAEC2CEC262A6A59-8022
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 903 Q    HW: 1Z0 920 903 Q
   Component: KOMBI         H05 0607
   Serial number: 00000000000000
   Coding: 410E00
   Shop #: WSC 73430 031 00066
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 43830A12CA9AFE06C91-8016
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 260212F1000458
   Coding: 351303
   VCID: 3A7D77F6B550BFCE9A7-806F
3 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 141
                    Mileage: 13926 km
                    Time Indication: 0
                    Date: 2018.14.03
                    Time: 15:55:19
01044 - Control Module Incorrectly Coded
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 10
                    Reset counter: 255
                    Mileage: 13926 km
                    Time Indication: 0
                    Date: 2018.14.04
                    Time: 09:13:47
03753 - Control Module for Microphone
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 13926 km
                    Time Indication: 0
                    Date: 2018.14.04
                    Time: 10:11:44
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: EADD07B60D704F4EAA7-80BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0000758
   VCID: 76E5A3C601C81BAEBEF-8023
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 68     3305
   Revision: 00H22000
   VCID: 377B6EC24642A2A6659-8062
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000758
   VCID: 48991D3E3BBCDD5E1C3-801D
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        010 0061
   Revision: 0A001001    Serial number: SKZ1Z3M0100575
   Coding: 0D0004000001
   VCID: 356764CA9C4E50B6775-8060
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012546
   VCID: 326D5FD6AD20478E527-8067
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33635AD2523A4E86591-8066
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664520028
   Coding: 0210000000010101
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 397F68FAB856B4D693D-806C
2 Faults Found:
9455635 - Telephone Microphone
          B1048 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 157
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 157
End   ---------------------------------------------------------------------
Edited by eggers
What's the loom like? My loom had some white connectors close to the head unit. It allows for Columbus voice control using the single Mic....
If you have them, try swapping them over. I think that if you have them wrong on the bolero, you effectivly have no Mic
Agree with above. Check connectors.
I don't think I've got the white connector version its pretty much this:
http://www.carsystems.pl/bluetooth-installation-kit-plug-play-for-7p6-and-5k0-module-foam-cover,id125.html
Which has quad lock connectors everywhere so everything goes in one way. From what I can see off of here:
http://www.my-gti.com/1313/volkswagen-rcd-510-pin-assignments
My mic connection is going to pins 1 & 7 which seems correct.
Any ideas??
There are three white connectors are in the middle of the loom in that picture, two are connected together when it arrives and the mic you fitted presumably went into the loose one? But if you swap those connections over before fitting the mic, it should then work.
Adam
Thanks guys, where the conenctors locked together so nicley I didn't think they were wrong. It was just a case as you all said of putting the white connectors together. So easy. And there I was testing everything with my multi-meter and convinced I had a dodgy mic... :whew::blush:
With that resolved I can't for the life of me get the stereo back in flush, :wall:  the new black multi-connector is just too big. Considering chopping a bit off unless there is a non-destructive solution?
If you take off the HVAC controls under the head unit (4 screws, and a couple of 1-way fit connectors) you can get you hand in and guide the cables down and into that gap......it's huge! I did this when I had an MDI kit in the car to take up the extra cable from the in-line connector.
Also make sure the aerial cables haven't got in the way of anything as the unit slides back in.
All done now!  :whew:  used the space underneath but still needed to remove a bit of the mounting with the hacksaw to enable the connectors to feed through.
  • 6 months later...
I believe that the three white connectors are as follows:
A. White socket connector with screened cable which goes to bluetooth unit - Microphone connection to bluetooth module
B. White plug connector (pins) with blue/white and white wires - Microphone output from Bolero
C. White socket connector with purple and black/grey wires - Microphone input to Bolero
On this basis I think that connectors A and B should be plugged together, and the microphone should be connected to connector C.
I assume that it is done in this way for one of two reasons:
1. To provide flexibility if the microphone needs to be fed to the bluetooth unit rather than the HU.
2. Because it is easier to do this than connect the screened cable to the pins on the multi-connector.
I incline to reason 2, but it is a bit confusing and I would have thought there would be a more elegant way of achieving the result if that were the case.
While posting, I need to source a microphone cable that goes from connector C to the microphone in the roof. Does anyone know where I can obtain one?
Edited by nickcoll
