BREMBO BRAKES advice
just got these brembos
1377076_10151935832748633_1009781670_n.j they are supposably from a porsche cayenne turbo they are the rears 4 pots and the part number that came on them are as follows
20 9236 06 2a/4a another number on them is 11n07 2 129          BM5 BREMBO they are genuine however cant find the part number on google to confirm wether they are actually cayenne turbo or boxsters i need toi know so i know what size discs they take and adapters to get for my fabia can anyone help please
kind regards Alex ps new to skoda just got a vrs absolutely love it
When I was looking at brake setups there were reports from people fitting rears from porsches on the front only to find they wernt much cope when it came to giving them some stick. Something about piston sizes and stuff I dont understand. Might be worth a ask about before spending any money.
I was going to say the same matt. I had a quick search on google aswell but couldnt find any info so thought i miss heard.
Its definately something to do with piston sizes. The rear calipers' pistons are too small.
There is a definitive brake thread if you search. Think it was "borrowed" from 'ukmkivs' forum
Pistons mismatched to you cars master cylinder, unfortunately if they are off a Cayenne you may need to stick your foot to the floor to get them to respond. Guys on the Golf R 32 OC have tried Cayenne calipers and had this issue.
Thanks for the replies guys it turns out they are VW Tourage 4 pots from the front I think so they may cope they should fit 350mm discs so anyone know where I can get some brackets made up?
If your search for VAGBremtechnic and contact Dave he should be able to sort some out for you.
Thanks southy I've looked loads and loads on then on internet and doesn't seen anyone had upgraded to these as a big brake kit all have gone the 6 pot route all I know is that these usually run 330mm discs so I think that the standard 334 r32 discs should work fine that way won't need to get any discs made up just ye adapters I'm going to measure the mounting holes on the brakes when they arrive see if they at the same distance as the Porsche adapter you can get on eBay
