online parts suppliers?
HI,
Any good onlilne parts supppliers out there in the UK that you can suggest?
I know the numbers of some bits I need as part of my gearshift problems. As I don't live near a Skoda/VW etc dealer, online ordering would be easier.
Thanks in advance.
Try calling this lot:
http://www.skodaparts.com/
I haven't ordered much but they were quick and reasonable. When I enquired on line one evening about an expensive part they phoned the following morning.
Thanks. I've emailed with the part numbers  I'm after.
1J0 711 203F  gear cable shift bracket (side to side lever) - this is the older metal bracket since replaced with poor quality plastic
1J0 711 761B  Gear cable clamp (for 10mm pin)
1J0 711 761C  Gear cable clamp (for 8mm pin)
N 908 159 03  Lock washer
1J0 711 067L  White plastic bushings to fit on lever pin
1J0 711 550    White plastic guide for shift bracket
Any other sources?
I want to create a spare gear cable bracket fitted with cable clamps and then do a straight swap. This way I can revert to original in case I botch it up.
Edited by jasper110
