Bob's Skoda Octavia vRS
Went to halfords fpr more paint. Got everything painted and 3 coat of clear 20140620_204350.jpg
Got the grill completely finished
Flattend back and polished
And finally on the car
Will get the bumper flattend and fitted tomorrow
Sent from my GT-I9505 using Tapatalk
  • Replies 64
  • Views 12.9k
  • BobIzYaUncle
    BobIzYaUncle
    This afternoons progress. . . Bumper and grill stripped, sanded, panel wiped and primered After 2 coats and 3 hour bake in the sun, the grill and bumper inserts got 2 coats of magic black T
  • BobIzYaUncle
    BobIzYaUncle
    This mornings progress. . . Got the bumper on the octy Flattend and polished one side Still got to flatten the other side but happy with results so far Sent from my GT-I9505 using Tapatalk
  • Nice work!
Edited by BobIzYaUncle
Finally finished the front bumper
Now alligns up well, the back parts will pull in more once the inner arches are back on!
A few months back I did the cold air feed mod but im concerned of picking up spray from cars on front when its raining!
So decided to keep the 3" feed, chop it down and locate it throught the arch. May not pick up as much cold air as previous but definatly will suck in more air than the original pipe
Also put the engine covers back on and had a quick wipe over
Next will be to start on wheels
Nice work!
Nice work!
Cheers mate, its been a bit of a pain but its been worth it. Just need to get my act together and get the wheels sorted the onto the suspension
awesome match! thought i did well today but that is epic :clap: :clap:
Todays progress. . .
Calipers were in need of some paint. I was originally going to go with orange to keep with the theme, but managed to find some green paint that is a near perfect match. . .and only cost 5.99
Some 'before' pics
Removed the pads to ensure I didnt get and paint on them.
Started off cleaning them up with a wire brush, also good for adding a 'key' for paint. Then gave a good wipe down with 'panel wipe'.
Once the panel wipe had dried, I then went around and applied 1 coat to all calipers.
Then by the time I had done the 4th caliper, the 1st was dry enough for a second coat and so on.
This is after 2 coats and still a bit wet
Soon after began to rain but lucky enough the paint is quite thick so the rain had no impact on the finish.
Once the rain had passed, went on to put the headlights back in.
They allign up much better with the bumper now and thw indocators no longer have a great gap between them and the wings.
The grey and orange wheel I did previous was going to be kept as the spare, but having cleaned up the other 4 wheels, Ive found one to be quite corroded. So ive decided to use that as a spare and repaint the grey and orange wheel. Got the tyre swapped over this afternoon so can start on the wheels tomorrow
Not much of an update but just a quick lick of paint on the inlet
Will get the bay cleaned up properly after ive sorted the wheels
This afternoons progress. . . .
. . . .started on the wheels. . . At last!
All cleaned up, sanded with 400 grit, filled all scuffs and finished with 600 grit
Gave the rears a coat of matt black
Lol
Got them in the home made booth!
And all primered . . .
Hope to get 2 coats of colour on by tonight will update again tonight or tomorrow so watch this space. . .
So. . .after 2 coats of colour
And so far, 1 coat lacquer
The wheels after 3 days of drying
Today ive managed to finish the following. . .
Fitted lowering springs 35mm but will only lower vrs by 20mm. They are prosport springs, only cost £70. Was told they were spacific for vrs and not golf springs but when they came the box had an octavia label over a golf label! However it sits pretty level where as golf springs usually cause the octy to sit about 10mm lower on the rear.
No pics yet as car is in a state and would spoil it to any pics up now.
Replaced osf ball joint
And in doing so, noticed alot of oil around the boost pipe from the intercooler to turbo, turned out to be a very weak jubilee clip which would have caused a boost leak. So replaced that also.
Got the tyres fitted back onto the wheels, all ballanced with new valves and bead sealed. Also fitted new centre cap decals and they look great.
Fitted the repacement wheel arch liners, will be added some louve into the off side soon for better cooling of the intercooler.
And finally taxed the bloody thing costing £146 for 6 months!
This weekends plans
Get it tracked up
Refit boot angle bars, started to remove for paint but they can wait.
Adjust rear silencer as its tilted slightly
And Hopefully. . . . . A full valet
Watch this space
Any more pics of ride height with the springs on? Interested to see how it looks
Will have after ive washed it mate. Looks a mess at the min and dont want to spoil it
wheels look great almost wish I'd kept my spiders
Alrighty then. . .
Done a bit of sprucing up
And . . . .
Compared to when I first got it less than a year ago!
Looks very well mate. Seems like you like the job done right and dont just bodge it as i would say. Maybe a vrs grill badge will finish the front end?
Yeah been lookimg for badge but not much joy! Are they the bolt on types like bolt through the grill onto a back plate?
And yeah, hate bodge jobs!
Little update,
Finally sorted the audio
The nsf speaker has never worked, so took door panels off to discover it wasnt even plugged in! Quick plug in to check all was ok and we had sound! :)
But the speakers which were fitted had too high a wattage. Speakers were infinty kappa push, 75w rms, my 4x50w sterio was never going to be enough and definatly not spending time and money on an amp at the min. I got some bose speakers 25wrms laying around which I had in the mx5, but originally came from a high end alfa 157.
Also wired back in the original tweeters. Sounds whole lot better
And the bose
And a little touch, thanks to crazygeordiegirl from ccuk forum for printing
Designed it myself combining the ccuk and briskoda forums although did take a little tweaking as the machine kept chewing up the print
  • 3 months later...
at last, an update. . . .
got a 12" fusion sub with built in amp. Not actually managed to secure it yet so currently strapped inplace with a ratchet strap. not the best, but its functional.
Need to sort the Head unit next as the volume button gets stuck and its looking tired.
fitted the standard rear springs back on as it sat too low on rear as lowering springs were for the Golf not Octavia! now sits a little higher than the front, future plan is to fit the modded top mounts off ebay which lowers front by another 10mm without having any effect on comfort, I will then prob refit the lowered rear springs.
replaced the N249 valve as I broke one of the plastic inlets when simplifying the vac system, but discovered its leaking vacuum so need to investigate into that more.
now for the not so good bits,
i was forced into a kirb a couple weeks ago and kirbed the drivers rear wheel, so will need to touch that up.
Been having difficulty getting the boot fully shut as the seal had stretch and was sagging! so took a trip up to chesterfield to see vrsmatt. Got a drivers door latch, passanger rear door latch, boot seal and passanger front wing.
fitted the boot seal and thats sorted the problem.
also, few weeks ago I went to Northampton to my niece's christening. Ive been having issues with the remote locking so currently have to lock the doors with the key in lock rather than remote. so this day I opened the boot as I was wanting my camera out, but then locked the car with the boot still open. gave the keys to mum to put in handbag with phone, and I got camera and shut the boot, not knowing she'd placed bag in boot whilst she put her coat on. so now my keys were locked in the boot!
A couple of bloke were more than happy to try and help pry the top of door open in attempt to open from inside whilst I was in church, but when I came out it wasnt good. not only had the failed to get in, but had caused quite a bit of damage to the paint work on the top of door and roof! Clearly realising there was no other way, I decided to smash the rear quarter glass, I was then able to pull the resr seats down and reach into the boot to for the bag witg my keys in.
So, was I got back it was another trip to vrsmatt for glass and drivers door seal.
Today Ive attempeted to change the drivers door latch, but with no luck. 1st off, I had to relace the microswitch on the replacement latch as this wasnt working, struggled to screw it into place so just used epoxy resin whuch seems to have a strong hold on it, got the door panel off, door lock out, all set to remove the latch and I could only remove one bolt, the other was so tight I stripped all the splines, so seems Im gonna have to drill it out or get a nut welded onto it so I can the undo it! so Ive just put everything back for now, hopefully get onto this again this week.
To make use of this afternoon, I set about sorting the damaged paint on the door and roof.
I will update more on this tomorrow and get some pictures uploaded.
pics now added
forge 007p thanks to k17keo
just thought, ive fitted this valve in reverse! will have to swap it round the right way doh!
Thats the correct way round isnt it?
I thought boost should be against the bottom of the piston, in its current position the boost is from turbo is directed at the side of the piston
I think this is quite a common arguement but personally I'd leave it as it is because any slight weakness in the spring would cause you to have a boost leak if you fitted it the other way round, the way you have it now that can"t happen.
