How to Adjust Camber?! HELP PLEASE
hi guys!!
This time i'm trying to adjust my camber...
I have bilsteins shocks with eibach pro-street lower springs running 18" VRS wheels (I own a Octavia Combi VRS 2.0tdi).
I want to upgrade to 19" but need to understand how to adjust the rear camber...I see some users made that, and already sent some PM but so far didn't received any answers  :(
Later i will buy some coilovers also to lower a little bit more.
I was to buy BMW X5 rear wheels 19 x 10J (already exchanged to 5x112) like Stamsaas has, but need to adjust the camber...how can i do that??
Also, it might by usefull to another set of wheels.
thanks!!
Camber is adjusted on the top suspension arm/link. You slacken off the nut on the arm and then rotate the bolt which has an eccentric washer fixed to it. This alters the camber.
Thanks! :)
Can you post a photo of that?? hihihihihihi  Language barriers :)
This should help.
Thanks!! :)
