Sidemounts
Done a search but no definative answer
Anyone fitted and running an upgraded sidemount intercooler? Easy to fit?
My brother has the turbo revs upgraded side mount on his tdi octavia, it should fit the Vrs too. You will need a couple of silicone joiners.
I'll see if I can get any pics of his set up
That would be great if you could mate. The ones ive seen on ebay do say for the 1.8 and 1.9 engines
I run one on my vrs, no issue with fitting, just bolt on & away you go
Thanks mate, which one did you fit?
I dont have any pics but as what dark_hero said i run a turbo revs side mount it was very easy to fit. You will need a couple of silicone joiners and some different bolts for the maf hope this helps
Thanks guys. If anyone else has any experiences please share
I would be integrated to see if the intake temps were much lower than a standard one if anyone knows?!?
