Water ingress.
Hi I have water coming into the car but only under the passenger seat every where else is dry. Could it be the door seal? Thanks
Sent from my R800i using Tapatalk 2
Have a search on here - this is a well covered issue!  The most common point of ingress is a grommet next to the pollen filter under the scuttle panel.  All water which drains off the windscreen on the passenger side goes over this grommet.
Also check for compost at the back of the front wheel arch liners which prevent water from draining well from under the scuttle panel.
