Seats
Would a full Seat Leon Cupra r interior fit in the vrs?
Anything will fit if your good with fabricating and a bit of DIY. direct fit then I doubt it but could be wrong.
Sorry is a golf mk4 interior in a Leon Cupra r
They will fit but would need bases changed over etc....
quite a few people have put mk4 golf seats into Fabia's now.
You also have a pm.
Thanks I've replied! Will the rear bench fit from a mk4 golf?
I'm doing this
Basically, get yourself donors that fit
Then you can just use screwdriver to prise out the full surround clip at the rear holding in the fabric
Takes a bit of work but it will come.
I would then just transplant the entire foam and fabric as its easiest rather than ****ing about with
Trim the foam where necessary and push in the plastic clip/surround at the back and alter as necessary, eg fabric for seat holes or release where in excess.
Don't bother trying to remove the release mechanism - the long bit will break on the process. Easier to just split the foam around the release to remove it. Job done. Its far easier once you've done it, than it looks, may need a bit of repair/bodging but as proven in early pioneeringposts by pastyboy etc, its definitely possible.
If you're wanting to put a mk4 golf interior in to a Leon, then it's a straight swap.
