Seat parts, Golf front seat lower subframes, Nice Fabia 2006 Seat covers + foam
1) Full set of nice intact standard Fabia 2006 covers, foam, and top seat frame.
Needs a bit of a clean but otherwise perfect
NOW REDUCED TO £15 + post for seat covers + foam and anything else left over (all the headrests, full set I think), top seat frame so they will switch straight over
Collect or post at your cost
as well as;
2) Seat spares for Golf:
height adjustable lower subframes and rear seat back frames came from a set of Recaro seats.
£5 ea
Ok some pics of the (loose) top and bottom bases,
note the flash is extremely bright and you don't normally see the stains (in daylight) especially but I've also made no attempt to clean the seat bases so I would expect them to come up well after a clean.
The other headrests and the rears are at least or better condition (not in pic)
Reducing the price of the Golf seat front metal subframes to £5 each
Ideally collected but post on top if you need them sent out, either organised by your at your own expense or what have you.
Now down to £15 for full set of Intact seat covers, foam + any other left over bits (inc. front seat upper frames, all headrests)
post or collect at your cost
C'mon its a much easier job to replace out the seat covers than you might think, especially if you just snip through the hog clips to replace them. You can then just use cable ties.
