All Sold
Hi Folks
As above all made by the electrical guru Korban from fabia mk1 forum
1/ This kit is brand new never been fitted I'm only selling as its far too hard to fit to a canbus vehicle I had one fitted to my fabia and its brill
post-10772-13864235323862_thumb.jpg £20 posted (SOLD)
2/ This kit was fitted to my Fabia high level brake light it pulses the brake light when you press pedal and then light will remain normal after pressed and after ten seconds it will pulse again if pressed or you can have it set to pulse every time you press . Only effects high level brake light ( passes mot as this type of kit is fitted on high end cars ) £20 posted
SOLD
Regards whoosh
I assume this would fit mk1 octy? where do you wire it in? as there would be no room actually where the high level brake is
I'll take the coming home lights!! PM me!!
I assume this would fit mk1 octy? where do you wire it in? as there would be no room actually where the high level brake is[/quote
I was going to fit it to my octavia mk2 .
Don't know what the room is like behind the high level brake light trim on a mk1 but it fitted no bother behind the trim on the fabia
Sorry you cut and put it inline
Pmd
Would a Phillips CANbus controller / warning canceller allow it to work ?
Don't think so the coming home lights get wired into the sidelights at rear of switch owing to it being canbus it was a no go
2nd (or 3rd?!) dibs if it doesn't go Whoosh :)
I will take both if anything else falls through!
I don't know, but my understanding is that the box of tricks clamps to the wire(s) thereby fooling the can bus system into thinking that all is well, whereas if you put LEDs in without the bulb warning light would illuminate as the canbus system thinks there is a bulb fault due to the low voltage of the LEDs.
I was wondering if the same principle would work on this kit?
Provisionally sold
Will be the brake light flasher work on all levels of braking?  If it worked so could sense when brakes were being applied harder than usual then fair enough. :)
was it Bimmer 1 bread wagons that worked like that or did they just get brighter the heavier you braked?
Korban was working on one that worked with a sort of mercury tilt switch that only worked under heavy breaking but this one works on all levels of breaking
Cheers whoosh
Coming home lights sold
Brake light kit sold .
Cheers whoosh
