3C8 035 730 D wifi
quick reply
he just told me that next week he is applying one on a golf, then he will let me know the coding and he also said that it will work on the latest iphones
we know it works with iphone. It works with any phone with hands free profile. What will not work though is rsap mode as rsap isn't present on the iPhone. It never has been.
Quick update, I cleared the error codes this morning but they returned immediately so I guess coding is required.
Also got another code pop up which looks to be battery related so think a newbattery is in order.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0537
   Revision: 00103 AC
   Coding: 40180AB8F00508C040080080110011E4037000AE626D8560E40440040000
   Shop #: WSC 73430 790 00999
   VCID: 326F1EFBD4BF
   Part No: 1Z1 955 119 C
   Component: Wischer 25050  22  0601
   Coding: 00D7B7
   Part No: 1K0 955 559 AH
   Component: RLS 260509 05  54  0402
   Coding: 0730ED
1 Fault Found:
00907 - Intervention load Management
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 111943 km
                    Time Indication: 0
                    Date: 2115.14.29
                    Time: 08:50:27
Hungry Horace, on 17 Dec 2013 - 19:59, said:Hungry Horace, on 17 Dec 2013 - 19:59, said:
This is the errors VCDS is throwing up. The only I have changed is the WSC code which was originally 00000 000 00000 as it was mentioned in one of the links above, but it hasn't solved the errors and I dont have a wifi menu. Any help appreciated.
Address 77: Telephone (J412) Labels: None
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0946
Revision: -------- Serial number: 35502105012766
Coding: 020000000100000000000101
Shop #: WSC 00028 028 00001
ASAM Dataset: EV_UHVPremi 002708
ROD: EV_UHVPremi_SK35.rod
VCID: 2443E8A39E4B
2 Faults Found:
9457427 - Negative output audio channel for speech/telephone
B104F 13 [009] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 111937 km
Date: 2051.14.28
Time: 17:01:15
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 137
Mileage: 111937 km
Date: 2051.14.28
Time: 17:01:15
Could this be a wiring issue maybe the loom is slightly different or the mic wiring.
Ensure these are set
-Antenna Diagnostic - inactive
-Telephone Baseplate Diagnostic inactive
 -Operating Unit for Cell Phone Preparation (3-Button Keypad) inactive -Operating Unit for Cell Phone Preparation (3-Button Keypad) inactive
Edited by TechieAli
I will look into the wiring and the settings you suggested. As it stands my iPhone connects to the system and I can receive and make calls.
The car had bluetooth phone prep factory fitted with bluetooth module 5N0 035 730 C which I removed and plugged the 3C8 035 730 D directly in.
I assume the wiring would be the same as a lot of functionality works its just throwing up errors.
Hopefully then its just one of those settings.
You won't get wi-fi with the iphone
the phone kit won't work in premium mode with an iphone (reading out of text messages etc)
If you want the wi-fi to work then you will have to use a different phone
Small update. As suggested I connected a different phone a Samsung Galaxy and the wifi options appeared. Now just need to do the other suggestions to fix the VCDS errors.
