HELP ME! GEAR BOX PROBLEMS !?!?!?!?!?!?!?!?!?!?!
Hello, Saturday I posted a post about my car making a noise. My mechanic and had a look at it, Gearbox has blown a few bearings. So in need of a new gearbox.
But can't afford a new one cus its £860 for a supplier to replace mine with a reconditioned gearbox...
Anyone know of anywhere I can get a secondhand gearbox? as looked on eBay and none on there...
Lord give me the strength not to just beat ten bells of **** out the car :(
EDIT:
Where can I find my gearbox code? I've looked In my boot underneath spare wheel and everywhere in the boot, can't find anything ?!
Edited by Kidson123
Not sure where you could find a cheap recon gearbox I'm afraid but I'm sure it's possible .
If you want to beat ten bells out of the car watch this video for some tips.
For sale section on here - might be someone breaking a VRS or two
Anyone know where I can find my gearbox code? Mines an 06 VRS. Just looked in the spare wheel well and nothing, no plate with information on or anything !?
Getting really ****ed off with this bloody car now.
:wall:  :wall:  :wall: :wall:  :wall:  :wall:  :wall:  :wall:
Get it repaired. Mine went, cost barely anymore than getting a replacement but I know its good for years now. Put a unknown used one in and it could do the same in 3 months time
That's so annoying. Feel for you matey :(
If you put more informationin the topic title though yyou're likely to gain more interest dude!
I have 1 finishing on ebay in a few hrs mate
Deffo gonna fit my 06 fab vrs???
Will have to see if I can sort a courier if it fits :(
yes will fit , may have different ratio's is all, I can stick it on a pallet for you/
Couldn't you look at other vags of same model? Or is that a no no
Yes, all six-speed PD130's use basically the same gearbox, as felicia16v says the actual ratios may vary.
Edited by sepulchrave
Look for a gearbox with the code HDS as that is the 2004 onward shorter ratio's box for the vrs
Edited by BigJase88
And that'll be correct gearbox for mine yeah?
YEAH!
Joking apart, if there is a gearbox specialist anywhere near you it wouldn't necessarily cost that much to get all the big bearings and seals replaced assuming all your intenals are intact, a complete recon with new synchro rings etc. probably isn't necessary, you should replace the clutch friction plate as well even if it's fine because you can get a friction plate relined for about £40.
Yes
Theres 3 on ebay from a quick 'hds gearbox' search
