2005 4x4FSI Octavia rear wheel bearing torque
Hi Experts
I just replaced my rear wheel bearings and on my 4x4 octy. Now my question is regarding the tightening torque of the 12 point bolt.
Some say.....
250nm back off half a turn, rotate the wheel ,then 50nm + 60 degrees
225nm slacken off( dont know how much) then 50nm + 60 degrees
70nm plus 90 degrees
I dont want to mess up the bearing so could you guide me into more happy miles!!!!
Regards
Stefan
The third figure is right. This is the procedure to use.
- Install new screw (twelve-sided bolt)
Note: The wheels should not touch the ground when tightening the screw for the drive shaft, otherwise the wheel bearing will be initially damaged.
- Depress brake pedal (assistance of second mechanic required)
- Tighten the twelve-sided bolt to 70Nm and release the brake pedal.
- Place vehicle onto its wheels.
- Tighten screw by turning it 90 degrees.
Thank you for the reply
Hopefully some more happy miles here in Sweden for me, better then the crunch from the back :)
Rgrds
