DSG oil + Brake pads
Skoda quoting me:
DSG Oil change: £219.95 (or was it £299?)
Rear pads: £99
Incl VAT/fitted
Any other dealer beat this price?
Hi Wayne,
I had my DSG oil and filter change done last month at RRG main dealer in Bolton for £150 all in, I was quoted the same price last spring but with low mileage and only a little over the recommended time I opted for a good detailing at Chris's and a chat with you!!
Although it's not shown on the website I think the DSG oil & filter change is included in the national pricing. Just mention some dealers are quoting £150.
My invoice breakdown was:
Labour. 0.80. £50.65
6F7 Filter. 1.00. £11.31
6G GETR. OEL. 5.00. £59.80
SPORD SEAL. 1.00. £3.25
Total £125.01
Plus vat and presume OEL means oil.
Mines the CR 170
Hope the above helps. Cheers Robert.
Sent from my iPad3 using Tapatalk
Cheers Robert!
I know DMKeith said they wouldnt match another dealer franchise.
But if its a national price - then will give it a mention!
Cheers again!
I will be doing my own DSG oil change in future...car out of warranty and i dont trust dealers as far as i can throw them i'm afraid.
Is it an easy job?
Oil cheap?
Ok
Just read DMKeith will MATCH any garage within 5 miles?
Is there a catch?
Surely a local garage will be cheaper!
Unless all DMKeiths are located in middle of Gobi Desert?
Is it an easy job?
Oil cheap?
Not a difficult job but you do need a special tool and VCDS or a code reader which will give you a gearbox oil temp reading (some people use a laser thermometer on the casing of the gearbox)...the temp has to be between 35 and 45 deg c iirc.
Oil is about £15 per litre and the filter is about £20...so all in £95 for parts.
There are how to guides on VWvortex and other places....the next time i do it i will post one on here for you all to take a peek at.
The special tool can be made quite cheaply using a new gearbox drain plug and a bit of plumbing.
However, to get the correct oil level you must follow the procedure particularly wrt oil temps.
Do u need a seal too?
