Troubles with Bolero
I have Bolero with Canton option and some days back problems with system started. Its just hangs middle of the music. I can choose different options like radio or media but no sound. Bluetooth call option is working. What I noticed that buttons on steering wheel doesn’t work. After system restart everything start to work again normally.  Another thing is with usb connection. In same cases it doesn’t recognize it. Then you need to plug it out and in again and after that everything works.
Does someone has noticed same problems with Bolero?
if i havent used usb, in a long time, i also have to plug it in and out. then it works fine. but maybe there is and update for the Bolero radio that will fix some of the bugs, Ask your dealer.
Start by removing any USB and SD cards to identify whether the base system is stable. If it is stable you may need to reformat or purchase new USB or SD media. It may be possible that too many tracks or file/folder structures cause processing problems for the head unit.
Had the same problem with my bolero which, on some restarts, occasionally and randomly do not recognise USB even if it was perfectly playing the last time i shut down the engine. I had to initialize the unit with a (very) long press on the power button and it then works as it should i.e continue the track where I left it. It happens 2 or 3 times a week :-(
Edited by mailme
