Replacing FL VRS front discs and pads what are torque settings please
Trying to find out the front caliper carriers, Allen key bolt torque settings please for when I assemble the brakes.
2010 VRS 312mm
Have tried searching forums but don't seem to have any.
Caliper carrier to hub - 190 Nm
Caliper to carrier - 30Nm
Disc to hub - 4Nm
(And just for reference of anybody else finding this:
Rear disc to hub - 4Nm
Rear caliper to carrier - 35Nm - Use new bolts
Rear caliper carrier to hub - 90Nm + 90 degrees - Use new bolts)
Brilliant thank you so much :)
Disc to hub - 4Nm
Can I buy the rear calliper carrier bolts from anywhere other than a main dealer?
Should be able to get them from TPS or possibly Eurocarparts
