Skoda yeti front disc/pad change, help
I am changing my front discs and pads, I'm experienced enough with doing this with cars over the years but there's a couple of things I need to know before starting.
I've got a skoda yeti 2.0 tdi cr 110 2wd model
Are bolts that hold the front caliper on need imperial hex keys? As metric do not fit.
Also
The wear cable which is only on the passenger side does not have the right connector to what's already there but also there's nowhere for the cable to go? There is a cable but it plugs into the rear of the hub housing. Is it possible I have no wear indicator? Or am I missing something? There does not seem to be pads without the wear cable for sale
Thank you for your help
Sam
The bolts that hold the front caliper on should be 7mm..... :happy:
Thank you, I shall double check, they are cap head bolts and none of my metric hex keys fitted. Maybe I didn't have a 7mm
7mm is not the most common - often left off/out of sets!
and the ones that hold the carrier should be 21mm..... :happy:
21 hex key? Spline? Or hex head bolts
I'm not sure your callipers are the same.....
I wouldn't of thought it would be a 21mm hex key, that's massive. Thanks for you help tho, just need to fine out about this wear cable now
The 21mm are normal hex bolts.....7mm are the allen sockets... :happy:
Edited by looby
I think they are called "multispline" as opposed toTorx.
Fred
Or just spline bits. Or triple square bits. Or triple square spline bits. Count the number of recesses, a torx bit has six, a triple square has twelve (hence the name)
