FL and Pre FL grilles
Are the the same fitment or did they change at the FL?
Edited by goshow
From what I can tell the bonnet is the same part so fitment should not change, I believe the FL grill wont fit when closed as it will catch on the none FL bumper as the FL bumper sticks out further if that makes sense.
There's a slight difference in the fitting pins as FL bonnet is about 1 cm longer where the grill is mounted. You can install FL grill to Pre-FL and the upper and side pins are on the right spot. It will not catch on the bumper. You have to bend the opening handle a little though... Other way around (Pre-FL grill to FL) would look silly...
Many thanks.
