hole where aux socket is?
Hi everyone I hope someone can help!  I've just bought my dads 57 plate vrs.  I've located the aux socket in the headrest but when i flip up the cover it just appears to be a hole.  i've just bought a bluetooth plugin for my htc one which comes with a 3.5 mm jack which from what ive read should fit.  if it doesnt could it be the worng size or is it likely that the fitting has fallen out under the arm rest.  if so is it easy to sort out?
Cheers!
I think they are prone to falling inside the jumbo box, there isn't much slack on the wiring.
cheers is it best to get someone to sort this or is a fairly simple task for me to do (bearing  in mind im lacking in tools and knowledge!)
I think you can do it with just a screwdriver. There is a thread on here somewhere with how to dismantle it.
In Technical guides I think
thanks both!
