Hazard Warning Lights Active / Emergency Braking
Hi All,
While doing some emergency braking the other day (keep your eyes on the road folks) i realised that the hazard warning lights were active for what seemed like ages. It was a blooming pain and i want to switch this off if i can.
I have had a look with VCDS and the box under "Emergency Brake Flashing via Turn Signals active" is definitely un-ticked !! Is this where i should be looking or is it located somewhere else.
Ta
Octavia II?
Mobile users can't see your avatar.
Sent from my phone so please excuse brevity and spelling
Octavia II?
vRS Blackline so I guess so.
Ok, not looked at an O2 for a while, but I seem to remember there was another setting somewhere.
I couldn't find another setting anywhere.
If anyone can point me in the right direction that would be great.
Did they not switch straight off when you carried on driving?
Also you can just press the switch to turn them off.
Phil
Flashing brake lights till you stop then Hazards and then Hazards go out when you move, or use the switch
I had to slam my brakes on at a set of traffic lights so i sat there with the hazards flashing (advertising the fact the i was not paying attention  :bandit: )
So basically i either have to move off or use the hazard switch to deactivate them?
Phil
Phil...Hi
I think I may have to meet up with you sometime soon
Mine are supposed to be activated, but don't appear to work
Thats pretty much it, they are designed to continue flashing unless the car starts moving again. The reason is safety, so that in the event that you had crashed into a tree or other object then the car will attract the attention of the emergency services. There would be no point if they stopped working after a short period.
Not all features can be disabled, even with VCDS. Especially the case for what is considered a safety feature. The same as you cannot stop ABS working for example.
Phil...Hi
You'd be surprised how hard you have to stomp on the brakes.
Plus they only trigger above a certain speed.
Don't mind having a look some time though. I'm over west Yorkshire way on Sunday 16th.
Phil
Ok Thanks Phil
PM'd my number
