Turbo Dynamics MD446 Stage 2 Hybrid PD130
Turbo Dynamics MD446 Stage 2 Hybrid PD130 turbo
Hi-flow GT20 compressor wheel
Re-profiled compressor housing to suit
360 degree thrust bearing
Modified turbine wheel blades to reduce backpressure
Blueprinting of turbo to motorsport standards
These are currently £882 including VAT from Turbo Dynamics
Fitted new on 27/08/09 at 50k miles and removed today (08/02/14) at 118k miles
Looking for £420 including delivery or £400 collect from near Gloucester
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
ohhh just when I'm skint, that would be a worthwhile addition to my rally car..
Bugger how much work has it done mate?
What power was it running at?
Should make 220 bhp easy.
You still have this for sale?
Would this be overkill to put on a stage 1 car?
Mapping wise would need doing again too i take it? Also would it be ok mapped to 170 hp as i dont wanna kill the car
It would be best to remap it to get its full potential
Yep
Bump
Bump
Bump
Bump
I was just looking at this on eBay what's the difference between the ASZ engine what this is for and the BLT engine
I think it's the position of the EGR outlet, wouldn't matter if you have an EGR delete.
This is my understanding too. The BLT has a shorter casting on the exhaust manifold to the EGR outlet so the pipework doesn't match up between an ASZ and a BLT. If you fit an EGR delete pipe or just blank the holes on the exhaust manifold and EGR then it should be fine!
Guest
