Breaking - mk1 silver 2003 Octavia vRS hatchback
vere3u4a.jpg don't suppose you have this pipe the one with the orange arrow do you mate ?
I can't be 100% but does this look like your pipe??
  • Replies 127
  • Views 9.7k
  • How much are you after for front brake set up Devon as i may be interested in them.
interested in a EHA gear box if you have one and how much would collect
Well, I had two lots of interest in the gearbox.  It's the stock 5 speed with the shifter tower removed.  Only want like £25 for it or so collected.
You wouldn't happen to have bumpers would you?
Nope, both gone. Front went real quick, rear only recently.
The bit arrived today cheers Jason you packed it well enough to me ten mins to open it :-)
Better than it arriving broken!  I always ensure stuff is packaged to a reasonable standard to survive usual courier / RM treatment  :thumbup:
Ha ha yeah defo mate cheers again
I now have two front struts (& rears in theory) dampers going cheap
Also the subframe and two hub housings with the bearings installed. :thumbup:
The bonnet is still attached to the car too.  Beer change for that!
Also found an airbox.  It's empty!
Have you still got the black door strips?
Rubbing strips?  No.  I actually only one have one door left, and it has no rubbing strip glued to it.
Don't suppose you have passenger front wing or a passenger front corner indicator?
Nope, both gone
Thanks for the offer of the box a bit to far to collect
When did I do this?  Not in my recent memory :D
Gearbox has now been paid for.
I will be heading from Devon to Aylebsury a week on Friday, and then to Bedford (autodrome) on the Saturday morning if I can help to bring anything else
ARB/subframe
Don't suppose you have any front springs do you jas?
The 4 springs went together quite recently. :(
Aww cheers anyway mate
Do you still have the drivers a pillar trim
Nope.  This isn't proving too fruitful is it.... :D
I recently got the inside A/C fan motor off :D
The car is now going to be scrapped very soon so last chance really is only for things already in boxes ready for me to move house, or already pictured here, or in the other thread "Can take to Aylesbury" :)
Scrap collection booked for Monday now.  Not long to go.  Some bits I noted still on the car and no plans to remove
Brake pedal
Clutch pedal
Indicator assembly
Bootlid
PAS reservoir over O/S engine mount
N/S engine mount
Found a great condition pair (i.e one.... :D) scuttle panel with washer jets / pipework when moving house, should anyone be interested.
The above box includes drivers switch panel, steering wheel airbag, I have mudflaps in the garage, headlight switch, washer bottle & pump, centre air vent, side air vent (but not sure which side) and some other sundries.
  • 2 months later...
Have u still got rear bumber
