Cruise Control
Right,
After completing my SMF conversion. I am on to the next job.
I am been to my local breakers and they have a elegance 1.8t estate... It has factory fit cruise control.
My questions are:
1st. how do i locate the looms of which i know i need two, 1 is stalk to bulk head other is a 101 pole ecu to bulk head.
2nd how do I remove said looms
3rd is there a guide of how to fit it all? so i know how to remove ?
4th do i need vagcom to activate it
and 5th (sorry) the donor is a 53 plate my car is a 2001 Y will it still fit?
Cheers,
Paddy
This is from a 2003 vRS Octy for reference.  I don't know if Y reg will take cruise.  Assume they all can?
http://www.briskoda.net/forums/topic/304668-octavia-mk1-vrs-and-others-cruise-control-stalk-%C2%A335/
and in relation to 4) Yes you do - Have to login to instrument cluster with a code (think its 11463 from memory) so that a G appears in the module title, and cruise is then activated.
If you google "seatcupra cruise" you'll probably find a handy guide you can use for your car - guide done using Leon Cupra from memory, which is basically the same/
