Stereo Surround
Hi,
Has anyone seen a mk 2 Vrs with the nexus sat-nav installed but with standard a/c only ? I'm retrofitting and the stereo surround is different between the stream and nexus. Is a different surround available ?
There is one available, but only in black. I had to fit one when I installed my RCD 310 DAB h/u.
I actually prefer the black finish to the silver.
I'll see if I can dig out a part no.
Think this may be the one you want
1Z0858069H 2AU finely turned aluminium
This is for Mk2 pre FL not climatronic, but check with dealer to be sure I am correct.
John
John
No. 9 in that diagram?
That's for the Stream, the Nexus/Columbus h/u is narrower so you need a different surround.
Right ordered it off there ! Now have the nexus , parrot with adaptor cable , ipod cable (replacing the multi changer and finally the surround. Just need to book her into Skoda as I don't have the code.
