Eric's started dribbling......
when you wash the rear screen water dribbles down the glass ( from the nozzle ) once the jet has stopped spraying, does it for couple of minutes then stops
rather annoying
Interestingly, for several months, my rear screenwash nozzle would drip about a mile after starting-out, and would then stop. It was doing this even though I had not used used them for weeks and weeks! Doesn't do it now at all.
Probably a bit of crud in the jet. Try squirting a little water back up the jet to free it.
They dribble as they get older :)
Sent from my PID using Tapatalk
have you tried abrupt braking? I have heard that shaking it a bit can help
Well, mine STOPPED dribbling as it got older.
Don't fill up the washer bottle and it won't drip?
Or is it just the start of a vapour trail from going so fast!!!!!!
ours has always done it... I assumed its just the way they are designed.
Not had it on ours.
Activate tear wipe and problem sorted.
