Tire pressure value can not be seen on central infotainment display
First of all sorry for this new topic.
As it is written in the users’ manuel and as i saw on the internet our cars should be show the tyre pressure values individually. That is to say; when i push the ‘tyre’ on the screen i should be able to see tire pressure seperetaly for each tire. I should be able to see pressure value numerically as one tyre’s pressure is 2.2 psi, the other one 2.5 psi and like this. Now there is no any information.
I add photos which shows the situation.
These are other photos:
Skoda includes the Direct TPMS instructions in the manual because they build heavy-duty fleet versions and armoured/high-security variants of the Superb that do require live pressure sensors. However, for standard UK/European consumer models, Skoda only installs the Indirect ABS-based TPMS
If your car actually had the system shown in the manual, it would require physical wireless sensor valves inside each wheel. If you have standard rubber or standard metal valves and the car forces you to manually hit 'SET' in the menu, your car has the standard indirect system and will never show the numbers
My Skoda has the similar screens for tyre pressure as yours.
Recently Browsing 2
