Starting problems on octavia L&K dsg
Hi my name is paul (username cobyjohn) I wondered if there is anyone out there that might have experienced the problem I currently have with my occty, she has been a good car to (2006) 150000 miles recently went to have a service ( had cutting out problems) found that the cranksensor failure, replaced. Then it was the camshaft sensor failure highlighted, replaced. Engine started fine running for about 20 minutes and stopped, started again (still at the garage) ran for 10minutes and stopped. Since then not able to start, had two VAG techs who cannot find the problem, the engine starts with easy start but not with fuel! Pump is getting fuel and they think each injector is working?? Crankshaft seal was changed using special tool. What could be the problem? Any thoughts out there
Which engine version?
It's a 2:0 litre BKD engine
Hi and welcome aboard.
