satnav map update never ends :-(
getting rather P***** off with this map disk not installing
even changed to a larger map partition to get over potential problems in 4120 and still.. 5 hours later.. no maps installed
what am i doing wrong ?
Edited by Tim_davies-moss
It might be the disc burning that has gone wrong???
maybe, but its done this one 2 different burned disks now with 2 diff downloads
veified data
had to burn to dvd as cd was too small
If its v8 or higher it will need to be a dual layer...
When you put the DVD in, you can confirm if the copy has started. After about 10 mins, try and eject the DVD. The columbus should prompt you and allow you to monitor progress, if the disc just ejects then the copy has not even started. The actual copy should take about 50 mins.
Ah, ill buy some
it does say unable to eject unless cancel download. but the progress bar gets close to the end then starts again. might be this dual layer problem tho ?
why dual layer tho ?
Size of the file is bigger than 4.7gb I believe.
O, so these 8.5 disks i burnt on must be dual leyer then. tidy
So that bits right
Thinking my HDD in the radio is shagged then. 2 disks from 2 diff downloads and still does it
Perhaps the problem is the pirate copies. See if your dealer does a reasonable price. You can get lucky.
if thats the problem then iv been unlucky twice and less hope of affording an original
