Sealant help
Hi Folks
I've been using carlak sealent for a few years it's nearly time to replace it as it running low .
I use collinite wax and was wondering what other sealant u folks would recommend just for a change
Cheers whoosh
Phew...Where to start...LOL
There are so many
Best thing I can suggest apart from the odd recommendation you may get is to have a look at what's available from several Detailing Supplers on't internet
I recommend (Due to ease of application):
Wolfs Nano Nano Salant (Hard Body)
Optimum Optiseal
Autobrite Hellshine Abyss
Poorboys EX-P
FinishKare 1000P Hi-Temp Sealant
I've only used fk1kp from Chris' lost above but that's the same as the collinite you already have!
Zaino or Jeffs Werkstat would be my recommendations :)
Happy sealing
Edited by Chris_VRS
Fk 1000P is a sealer Chris...Collinite is a wax
I've recently purchased some optiseal that Chris mentioned above and been very impressed with it. Really easy to apply, just spray on a very small amount and use a pad to cover the whole panel, and that's it. No buffing etc.
I'm no expert but would certainly recommend it.
Is Jetseal 109 a sealant or wax or can u wax over it
Cheers whoosh
Jetseal is a sealent. Yes
You can wax over sealant but should not seal over wax
Cheers I think I will give jetseal a go
Thanks for the help
Regards Whoosh
Think you'll find they are both hybrids Chris ;)
Thought Jetseal was a sealer
We live and learn
All products listed are either sealants or hybrids.
Then look on here or DW (as well as ebay) for someone selling cheap.
You have anglewax near (ish) maybe contact them for a deal or two?
