Tow bar removal
My Octavia has a removable tow bar with a key... How does it come off??
Thanks in advance
Tom
I have a Witter towbar fitted so I give you its instructions although other will be similar.
You should have a key - unlock it
Push the knob in and turn
The locking pin should release and simply drop out.
To refit push in the knob and turn - little pin pops out
Push it into the holder and then pull forward
this causes the pin to be pushed in and applies the locking pin.
Use the key to lock so it can be accidentally released or Stolen.
If it's a Skoda factory fitted towbar then you turn the key, then push the lever away from you about 45 degrees (it takes a bit of effort) and the towbar will then just slide out downwards. To refit do the reverse procedure.
Thanks guys. Will give it a try tomorrow.
Removed... thanks guys.
