octavia vrs mk 1 tracking
hi guys just got my rainsport 3s ready to fit to my new alloy wheels phoned up to get tracking done aswell and they say they cant give me a price on the tracking untill they see it as it could have possibly 6 adjustments on it so could cost up to 96 pound does this sound right to u guys all help is much appreciated
I thought it was just front ?
£35 here
u are probably right lloyd mate as they said they couldnt say without seeing it
Yep, just the front.
However they should put it on the 4 wheel alignment rig, so you can check that nothing has been bent at the rear and the wheels are facing the right direction. There is no point in aligning the front if the back end is going the wrong way. If the back end is way out, your in to replacing suspension components, if its a small amount then I Believe it is possible to make small toe adjustments on the rear by loosening and moving the rear sub frame.
hopefully nothing is bent as i have had all suspension out and replaced most components springs shocks etc in the last 6 months but fingers crossed everything is ok :)
£35 :0
£21 around here
Brizzle prices lol
Protyre will actually pop it on their fancypants hunter stule thing for fweeee
Only charge if adjust anything :)
Usually around £30 round my way!
