octavia vrs dashboard lights not working
Hi all, my fuel and temperature cluster on the dash lit up when driving but after a few just those two lights go off, i haven't checked the fuse yet, but if the fuse is fine, then what could the problem be?:-(
corrosion / bad soldering on the instrument panel, if everything else works ok, and they work intermittently, that definitely says circuit board problem by my mind...
or just a dead bulb/led in there...
Edited by mac11irl
Well I've had the cluster bulbs changed to white LEDs, so could the soldering be the problem, if the fuses are fine??
that would be my first check yeah... esp if theres work been done.
clusters are known for dodgy solder joints, so worth looking into..
