VRS 07 Hydraulic or Cable clutch?
I have done some searching, on here, google and in the service. However I still don't know weather my 07 Octy VRS tdi has a hydraulic clutch or cable?
If it's hydraulic..is the fluid shared with the brake fluid?
Many thanks.
I believe its hydraulic and the fluid is shared with the brake system.
Okay. If this is the case..if I were to bleed and replace brake fluid would that also class as a clutch fluid change?
There should be a bleed nipple on the clutch master cylinder.
Right okay. But would I fill the clutch fluid up in the same place I put brake fluid or are there two separate reservoirs?
Same reservoir. Do the clutch before the brakes and take 200ml of fluid from the bleed nipple. Access will be improved if you remove the air filter box.
I don't wanna seem dumb but I just want to double check. My brake fluid got changed a few months ago by a dealer .. Does that mean my clutch fluid was also changed as there from the same container?
