Squealing breaks?
My breaks have begun making a ridiculous noise.
The squeal when moving and when breaking!
Time for new pads?
In a word, yes :)
If they're squeaking while moving, you might also have a stuck caliper, which is very common.
Ah i thought as much! Job for the weekend then!
Not necessarily.
Check the pads first. Some pads do squeel after a while... grinding means new pads but squeels sometime just happeb.
if your pad is ok for meat just take out, put a bit of a chamfer on leading amd trailing edge theen with a hack saw cut a groove deep in the middle of the meet
__________________
_______ !_________ where this 'dotted' line is :)
I just put pads in dry most of the time of a touch of bosh super fit for brake pads if you must. But lube also holds dirt amd dust
ah thanks ill have a go tomorrow!
My drivers side has just started squeeling.. pads were new on in august 2013 and ive probably covered around 600 mile since being fitted
Mine only squeel once ive been driving for around 15,mins and only under 30mph
Exact same for me! Ever since this dry weather has come
I may have a stuck rear calliper, what's the remedy?
Red rubber grease on sliders??
Absolutely not, red grease is red "rubber" grease, ie grease that will not swell up rubber, you need silicon grease on these sliders is at all.
i don't think so no. I'm pretty much a novice to breaks so gonna take them off today and have a look.
Got this problem with my vrs now. Was it just cheap pads? Calipers sticking? Calipers needing some copper slip?
Sent from my HTC One X using Tapatalk
Just did this a couple of days ago front drivers side squealing like mad one pad was jammed on a bit just a good clean up of discs and pads making sure the pads pretty much fall in copper slip on all contacts and in behind the caliper carrier rubber slide pins and the pads  once I did that runs a treat
Have a break, have a Kit-Kat :rofl:
Because race car
Cheers Joe will give that a go!
